PXI
PXI-7831R: Calibration procedure ?
I did not find the information about a calibration of PXI-7831R
Does it module have the procedure of calibration ?
(2,742 Views)
This user manual has some information about calibrating the PXI-7831R card.
https://www.ni.com/docs/en-US/bundle/pci-pcie-pxi-781x-783x-784x-785x-getting-started/resource/37325...
(2,713 Views)
There I did not find the information about procedure of calibration.
(2,706 Views)
I found an R Series Calibration Procedure PDF here:
(https://www.ni.com/docs/en-US/bundle/r-series-cal-pro/resource/4018670.pdf)
If this document doesn't give enough information, you might need to contact NI about calibration.
(https://www.ni.com/en/shop/services/hardware/calibration-services.html)
(2,701 Views)
