PXI
PXI 8106 RT
Hi, evry!
I've just received PXI-8106 RT controller and wanted, as usual, "clear it up" with Firstware, but...
...have "F4" pressed during bootup - nothing happened!
So... Should there be a Firstware on RT controller?
...Not a word 'bout it in manual, by the by....
Thanx in adv.
Message Edited by Sharonoff on 10-16-2008 07:25 AM
Message 1 of 8
(5,500 Views)
The PXI-8106 RT doesn't come with Firstware.  You can create boot disks (or USB keys) through Measurement and Automation Explorer.  Select Tools»RT Disk Utilities and select the option you'd like.  The Format Hard Drive Disk utility will give you the option to format the hard drive and put the RT OS back on.
Caleb W
Message 2 of 8
(5,479 Views)
Thank you very much, Caleb.
And...
1.    Can Win XP be installed on 8106 RT controller for RT and XP to coexist?
2.    Is it possible to install Firstware on 8106 and if yes then how?
Thanx in adv.
Message Edited by Sharonoff on 10-20-2008 01:54 AM
Message 3 of 8
(5,457 Views)
Hi Sharonoff,
Dual booting your controller is possible, but it is an unsupported feature.  We have a KnowledgeBase article describing how to do it here: http://digital.ni.com/public.nsf/allkb/B106BD4C654F0F2A86256E8E00245C84?OpenDocument .  This is a feature that is provided more as a proof of concept and you will have to repartition your hard drive.
To install Phoenix FirstWare, you'll need to purchase a license from them.
Caleb W
Message 4 of 8
(5,436 Views)
Thanks!
Message 5 of 8
(5,412 Views)
...Ah, and one more moment, Caleb.
PXI-8106 controller i've spoken about above came equipped with 2GB of Samsung RAM-memory (2x1GB).
And these banks has no NI catalogue numbers in it's stickers, while...  controllers received before (for instance, PXI-8186) has Southland memory WITH catalogue numbers.
What's up with NI catalogue numbers upon memory's stickers?
Thanks in adv.
P.S.: Some NI local representative said it's O'kay 'bout Samsung memory, while i've always seen "NI" memory WITH catalogue numbers before ;).
Message 6 of 8
(5,323 Views)
Some of the controllers have different RAM chips.  If you pull out the Samsung RAM, you may see a cataloge sticker (depending on which RAM chip is in your controller) on the other side.  These aren't NI cataloge numbers, but rather Samsung or Southland.
Caleb W
Message 7 of 8
(5,303 Views)
Accepted by topic author TerraNova
OK, thank you!
Message 8 of 8
(5,294 Views)
