PXI
PXI-8145 RT configured with LabVIEW RT 2009 running SVE, is it possible?
I'm interested  in knowing if the "SVE" (Shared Variables Engine) can run on a PXI-8145RT configured with LabVIEW RT 2009? My needs would be only a few boolean variables. Has anyone tried this configuration?
Michel
(3,577 Views)
Hello Michel,
This is definitely possible, you'd need to add the real-time software to the controller and then create a LabVIEW project including that PXI target and use your variables in the VI running on the target. The SVE is a software framework that enables a networked-published shared variable to send values through the network. You can find out a bit more in the Shared Variable Engine section of this Developer Zone Tutorial. Post if you have any questions.
Thank you,
Deborah Y.
Deborah Burke
NI Hardware and Drivers Product Manager
Certified LabVIEW Architect
(3,566 Views)
Accepted by topic author Michel_Gauvin
Thank you for the information. The upgrade was successful.
Michel
(3,551 Views)
