PXI
Simple VISA Setup Problem
Hi all,
I'm having issues working with VISA in LabVIEW. Previously, I've used Peek/Poke VIs (before they were VISA VIs) that allowed me to read and write directly to registers at a given Windows address. I have a new, custom PCI Express board that uses the same architecture that I've worked with previously only this time I'm trying to access the registers using VISA.
As this is my first time using VISA, I'm having some setup problems. Yesterday I got to a state where logically things should work but I still end up getting an error when I try to run a simple VISA Open command (see attached screenshot).
The initial problem I had was I was not able to acquire a VISA resource that opens a session to my PCIe board...it would simply not show up on the resource list. After reading around I discovered I needed to create a custom VISA driver for my board. Once I did that using the VISA Driver Wizard, the device showed up in my list (as seen in the screenshot). I wrote the simplest of all VIs where I simply open that VISA resource, however, the error seen in the screenshot is produced.
I'm pretty sure this is a simple setup issue, but does anyone know what I'm doing wrong?
(3,208 Views)
Hi bonhomme,
I see you're having some issues using VISA. It sounds like you're new to VISA, so I wanted to pass along some information that we have availble on this software. This link gives good general information about VISA, and the related links are extremely helpful in finding specific issues.
Thank you for attaching your error. This is extremely helpful in debugging since we can actually see the numbers. There is another forumn that talks about these at this link and at this link
Hope this helps you out!!
Lea D.
Applications Engineering
(3,193 Views)
