PXI
PXI 8156B Battery Failure and restore harddrive.
I am working on restoring a very old system built using PXI8156B, attached are the snaps.
The system has damaged OS. I want to restore by ghost image which was captured just before final system was ready for operation.
The CPU module has battery failure which cause "Loading defaults" thereby booting from C. I tried making boot sequence "A,C" but was no success.
I would like to know how do I restore the battery..? There doesn't seem removable battery.
How can I restore the ghost image if battery solution fails..?
Kindly advice.
Thanks and regards,
Kunal
Message 1 of 1
(5,111 Views)
