PXI
Why not PCI
I am looking a few good reasons  why i should upgrade my PCI based tester to PXI based tester -
Some of the thoughts I have -
1. More variety of cards available in PXI section.
2. Higher speed.
thanks
jis
(5,556 Views)
More slots.  You can get an 18 slot PXI chassis.  Good luck finding a motherboard that can have that many PCI cards.
Shared triggering and clocks in the backplane is another one that I really like.
(5,548 Views)
You can get 18slot PCI chassis which can work with a normal PC.
(5,544 Views)
Huh, never looked for a PCI chassis before.  Interesting.  But if you are doing that, you might as well just go PXI.
(5,542 Views)
PCI chassis is much cheaper than PXI!
(5,540 Views)
