PXI
PXI 8196 - Serial Port Problem ?
I have a third party instrument that we communicate with via PXI 8196 over the serial port. When I use VISA close or close LAbVIEW it closes the serial port, but I lose connection with the instrument. I have to manually reset my instrument to operate again. I used VISA monitor and found that whenever I close the instrument via PXI, it throws a HEX character /x00 which is ascii equivalent of NUL.
I tried doing the same exercise using my PC and I was able to close the instrument and open it via LabVIEW.
Looks like when I close the instrument through PXI, I lose connection. Any thoughts ?
Kudos are the best way to say thanks 🙂
(3,615 Views)
Hi Spartan00,
It appears that this is an issue that National Instruments is aware of and working to correct.  Best of luck with things in the meantime!
Anna M.
(3,554 Views)
