PXI
PXI 8252 doesn't recognize FireWire Hard Drive
I'm trying to connect a LaCie FireWire Hard Drive to my PXI system using the PXI 8252 card. I followed all the steps in the NI-1394 External Drive Support Tutorial, but the PXI system still does not recognize the drive. The Drive is Formatted in FAT32 and
NI-1394 External Drive Support 1.4.1.3.0 is installed on the PXI. Either using FTP or the LabVIEW File I/O primitives, I can't seem to find the drive. Also when I run the NI-1394 External Drive Enumeration Example on the PXI system with the FireWire drive connected to system, it doesn't find the drive.
On the PXI system (PXI 8186) I'm running Labview RT 8.5 and also the OHCI Compliant IEEE 1394 Host Controller work perfectly, other FireWire products have no problem working with the PXI system.
Hopefully, somebody can help me with this problem.
Regards, Sebastiaan.
Message Edited by SebastiaanNL on 04-22-2008 03:37 AM
Message 1 of 1
(3,206 Views)
