PXI
PXI-DAQ module does not pass test in MAX
I have just upgraded a PXI/SCXI system by replacing the controller module with a new one (8176). I did not change any of the other hardware. The DAQ is controlled by a PXI-6040E, which is in the last slot of the PXI chassis to control a SCXI-1100 with a SCXI 1320 terminal block in the SCXI portion of the chassis.
After installing the new controller, and installing LabView, I added the PXI chassis and the 6040E into MAX. The testing states that the 6040E does not pass the test, and that the chassis configuration cannot be confirmed. The 6040E is listed in the hardware/device manager for Win2000 and is listed as working properly.
I am looking for a troublshooting strategy, and I haven't found quite what I needed on the NI web
site. I have updated the pxi ini file, I've got the latest version of NI-DAQ. I have a feeling it must be something simple, such as a driver, or Win2000 related, because the system worked properly before I switched controllers. Thanks for your help.
-Sue Kristoff
(3,282 Views)
See
http://exchange.ni.com/servlet/Redirect?id=8487758
Regards
Filipe A.
(3,282 Views)
