09-15-2006 12:55 PM
09-16-2006
11:51 AM
- last edited on
03-12-2025
11:22 AM
by
Content Cleaner
You actually have quite a few options for triggering between PXI and traditional instruments. Best case, your GPIB instrument can output some hardware signals like a sample clock, reference clock or start trigger that you can then wire into your PXI system to take measurements. If you are only synchronizing a single PXI module to your GPIB instrument and want to save some cost, most modules can accept these external synchronization signals directly (usually via PFI lines). If you want scalability or want to synchronize multiple modules to these signals, you can also import the clocks into the chassis' timing and triggering lines with a Timing and Synchronization module. This option would allow you to synchronize up to 16 modules to your GPIB instrument (using an 18-slot chassis).
