PXI
limit characters in a string input
In LabVIEW, I'm trying to limit the number of input char entered by the operatot to 8 char. How do I set the string field to accept only 8 char and ignore the rest.
Dan
(4,216 Views)
to limit the number of input char entered by the operator to 8 char,
the simplest method would be to find number of characters by using 'string length' function. If the length is longer that 8 characters, pop up a message stating so(optional) and ingnore/reject that string
To do this, use 'String subset' function, with offset=0 and length =8
Message Edited by devchander on 09-14-2006 10:28 PM
(4,211 Views)
A small tip.
In future, post your labVIEW related queries in LabVIEW discussion Board for a quicker response Smiley Wink
(4,209 Views)
This should do it too. Look at the attachment
Chetan K
Application Engineering
Message Edited by CKap on 09-15-2006 09:29 AM
(4,209 Views)
Thank you all for your responses. That would give me a lot of ideas to work on.
Dan
(4,200 Views)
could you please post a picture of block diagram of your limit_to_8.vi??
(4,189 Views)
Here you go Dev.
Chetan Kap
(4,180 Views)
