PXI
PXI Physical channels in LabView - PXIe-2727 board
Hi all,
first of all sorry for my simple question but I'm a labview beginner and i don't understand how to use a PXI enviroment.
My system is made of  a PXI with PXIe-2727, PXIe-4300,PXIe-4332,PXI-2510 and PXIe-2658 board and Labview is 2016 version.
If I correct understood, before to use DAQmx driver into VI, I need to map the real HW on virtual channel via MAX
My target is simulate a PT1000 sensor using PXIe-2727.
Under MAX I see all HW but when I try to create a virtual channel for PXIe-2727 I don't found it
On MAX tool my step were :
1.select Remote System->NI-PXIe8880-zxcvbn->Data Neighborhood
2. right click Create New
3. On dialog window, select NI-DAQmx Global Virtual Channel and next
4.Choose Generate signals->Analog output -> Current and I see only PXIe-4332
I check in other sections of Create New NI-DAQmx Global Virtual Channel without found PXIe-2727.
Suggestions ?
(3,296 Views)
(3,198 Views)
