03-29-2017 04:58 AM - edited 03-29-2017 05:00 AM
Hi all,
first of all sorry for my simple question but I'm a labview beginner and i don't understand how to use a PXI enviroment.
My system is made of a PXI with PXIe-2727, PXIe-4300,PXIe-4332,PXI-2510 and PXIe-2658 board and Labview is 2016 version.
If I correct understood, before to use DAQmx driver into VI, I need to map the real HW on virtual channel via MAX
My target is simulate a PT1000 sensor using PXIe-2727.
Under MAX I see all HW but when I try to create a virtual channel for PXIe-2727 I don't found it
On MAX tool my step were :
1.select Remote System->NI-PXIe8880-zxcvbn->Data Neighborhood
2. right click Create New
3. On dialog window, select NI-DAQmx Global Virtual Channel and next
4.Choose Generate signals->Analog output -> Current and I see only PXIe-4332
I check in other sections of Create New NI-DAQmx Global Virtual Channel without found PXIe-2727.
Suggestions ?
03:05 AM
- last edited on
09-23-2025
10:51 AM
by
Content Cleaner
here you can find some useful documents about NI PXIe 2727:
https://www.ni.com/docs/en-US/bundle/pxie-2727-specs/page/specs.html
https://www.ni.com/en/support/downloads/drivers/download.ni-272x-reference-vis.html
https://download.ni.com/support/softlib/switches/NI-272x%20Reference%20VIs/NI-272x%201.0/Readme.html
https://www.ni.com/docs/en-US/bundle/373198j/resource/373198j.pdf
These may help you in configuring MAX, making your connections and starting your LV developement.
N.
