10-12-2015
02:25 AM
- last edited on
05-13-2024
11:40 AM
by
Content Cleaner
I am having NI PXIe-1082DC PXI Chassis with NI PXIe-8135 (PXI Control Unit), NI 5781 Baseband Transceiver and NI PXIe-7962R (FPGA).
So with these above modules can I run this example code (https://decibel.ni.com/content/docs/DOC-40747 ). Btw I am having LabVIEW Communications System Design Suite 1.0.
JK
10-12-2015
11:53 AM
- last edited on
05-13-2024
11:41 AM
by
Content Cleaner
Hi JK,
Thanks for the post. With your current hardware, you would unfortunately not be able to run the example using LabVIEW Communications. With FlexRIO, LabVIEW Communications only supports the newest, large Kintex 7 FPGA targets - the FlexRIO 7975R and 7976R. It also only currently supports the newest baseband FAM, the NI 5782.
What type of application are you working on? Have you been working in LabVIEW Communications, or are you just evaluating? Feel free to private message me if you want to follow up directly.
Also, the the 1.1 service pack recently release -
Thanks!
