PXI
PXI remote controller
How do i choose PXI controller -
1.  When should i pick Remote PCIe controller over Inbuilt PXI controller ?
2. Can I  buy a high RAM/hi speed controller desktop PC with remote PCIe board  and avoid buying high cost PXI inbuilt controller
3. What are effects on Real time testing while using remote PCIe controller
you replies appreciated
thanks
jis
(5,256 Views)
95% of my applications use a good rackmount PC (decent CPU, full up RAM, and RAID 1) and use MXI Express to connect up to a PXI chassis.  Each instrument is technically sharing the PCIe bus.  But that only really matters if you need a really high throughput.
About the only time I would use a built-in controller would be when I need an RT system or am trying to make a stand alone PXI chassis.
(5,236 Views)
