PXI
PXI trigger on XNET CAN frame receive
Is it possible to generate a trigger such as PXI_trig0-7 or RTSI by XNET session when a CAN frame is received?
I use NI PXI-8512 to receive CAN frames from an angle sensor with a period of 10ms and I would like to synchronise it with the reference of the servo that rotates the sensor. I use PXI-7350 motion controller. My plan is to use buffered high speed capture, but I did not find any simple solution or workaround to generate a trigger signal only when a CAN frame is arrived.
Looking forward for suggestions, ideas!
Message 1 of 1
(1,728 Views)
