PXI
Remote File Browser and non-blank password
I work with a PXIe 8821, and I use also TestInView to communicate with it.
With TestInView I can create a "Plan d'archivage", which saves in real time the value of each Input/Output.
Before, we had an older PXIe and everything worked well.
But with the PXIe 8821 we are unable to download data's.  I assume it's due to the fact that we can't reach the ftp server with the user "admin" with no password.
If I go to the PXIe's adress, ftp://admin@172.16.... , the web browser doesn't let me access to data's. If I try with an other user, with password, it's works fine (But TestInView doesn't use this User).
Is it possible to deactivate the function which prevent me to reach the ftp server with user (admin in this case) without password?
By advance, thank you.
Message 1 of 1
(2,293 Views)
