PXI
PXIe DMM is found in MAX - but, not within the PXI Chassis Tree
I am having trouble installing a  DMM in a PXIe-1085 Chassis....
The DMM, despite my best efforts, refuses to display under the PXI chassis tree in NI-MAX.
I have tried:
1) Removing all other PXI cards in the chassis
2) Installing the DMM in a different PXI slot
3) Installing the DMM in a different PXI chassis (same model)
4) Using a different PXI Remote Control Module
5) Resetting the Configuration Data (via the MAX tools menu)
6) Deleting pxisys.ini and pxiesys.ini files and rebooting
7) Updating NI-VISA (ver 19.1 to 19.5)
😎 Updating NI-DMM (ver 19.1 to ver 19.5)
I'm not sure what else to try.  Has anybody else seen this?
(1,990 Views)
Some more information that may help...
From a fresh reboot... I can:
1) Open NI-MAX (DMM is not found under the PXI chassis)
2) Close NI-MAX
3) From Device Manager, update the DMM driver (Browse my PC for driver > Let me pick from a list > Select NI PXIe-4081 > Select Next)
4) Open NI-MAX (DMM is now located under the PXI chassis as I would expect)
5) Close NI-MAX
6) Reboot the PC
7) Open NI-MAX (DMM is AGAIN not found under the PXI chassis)
It seems the pxiesys.ini file is getting changed on re-boot...
from (step 4)
[Chassis1Slot14]
SlotType = "PXIeHybridSlot"
SystemSlotLinkOrigin1 = 2
SystemSlotLinkOrigin2 = 2
PeripheralSlotLinkWidth1 = 8
PeripheralSlotLinkWidth2 = 0
LocalBusLeft = "Slot13"
LocalBusRight = "Slot15"
Model = "NI PXIe-4081"
Vendor = "National Instruments"
ModelInstance = -1
InstanceName = "1093 C4C4 1093 76D8 #1C9AD06 (17,0,0)"
AddressInfo = "PXI0::23-0.0::INSTR"
PeripheralModuleOccupiedSlotList = "14"
PeripheralModuleLinkWidthMax = 4
PeripheralModuleLinkWidthNegotiated = 1
to (step 7)
[Chassis1Slot14]
(1,958 Views)
