LIONCSU,
Are you sending a signal to the 5411 that ramps up to 10V or are you simply generating static DC voltages? Can you elaborate on what you are seeing and what functions/examples you are using to generate the signal? It sounds like the output drops and returns back to the expected value when outputting DC values greater than 5V. Is this correct? If so, how long does it take for the voltage to stabilize. Are you applying and DC offset or attenuation? Unless the 10 dB attenuator is switched on, which occurs when the gain is less than 1.58 V or the amplitude is less then 3.16 Vpk-pk, the waveform maximum plus the offset must not exceed ±5 V into 50 Ω if it does, the waveform is clipped.
Shea C
Applications
NI
