PXI
Using the GPS - Time N Software Events (NI-TIO) VI. Crashes every 15 seconds
Have a PXI-6608 in slot 1 of my PXI chassis which has an RT Module. Have DC Demodulated IRIG wired to PFI Line 6. When I download into real time controller and run GPS - Time N Software Events (NI-TIO) VI you include in examples it appears to work correctly but then seems crashes every 15 seconds, recovers, and runs correctly again for another 15 seconds.
(2,927 Views)
Hi oaklejd,
Do you encounter any errors when running other NI-TIO examples (this can help us identify if the problem is with the example or the hardware involved)? When the program crashes, is there any error/feedback message? Does it recover automatically or you have to end the task manually? Also, which version of LabVIEW and the DAQ driver are you using?
A few troubleshooting suggestions:
- Try running the example in highlight execution mode and monitor it. Does it still crash? If so, what operation is it performing when it happens?
- Try using the device in a different slot
- Try using the other counter to see if the same occurs
Lesley
(2,916 Views)
