PXI
PXIe-1071
I have the following setup:
PXIe-1071 chassis with a PXIe-8821 controller  and a NI PXIE-7975R adapter connected to a NI 5782 transceiver.
The PXIe chassis is not identified automatically in MAX as it should be. Furthermore, when I choose 'Identify as' the PXIE 1071 does not appear on the list. When I choose 'Identify as' --> other and use the file in 'National Instruments/ PXI/ PXIe Chassis' I get an error (0XFFFB380E).
Under the 'Unidentified' Chassis there appears a 'PCI bridge (remote Controller)' , but also there it is the PXIe8821 does not appear on the list.
I am running Labview 2015 SP1 (32-bit) on  windows 7 Enterprise (64 bit).  Also tried on Labview 2013 (32-bit) .
All the software packages that arrived with the hardware were installed: PXI Platform Services 17.0, Device Drivers (August 2016).
Thanks for any help,
PAPA
Message 1 of 1
(2,683 Views)
