PXI
PXIe-1073 Power Resistor
Does anybody know what the power resistor (6Ohms, 50W) is for?
I changed the power supply and don't know its right to connect it directly to 12V?
Thanks for answers.
(4,175 Views)
Here is a picture. I checked with another working system. It gets really hot. What is this for?
(4,148 Views)
Does anybody know? Thanks!
(4,130 Views)
It looks like a heater ... does the manual says something about housing temperature control?
Or a minimum load for the switched power supply?
Greetings from Germany
Henrik
LV since v3.1
(4,127 Views)
Thank you very much. This are my assumptions.
Does anybody knows for shure? Anybody from NI?
(4,119 Views)
I'm afraid no one from NI is going to share with you the details of Internal Chassis Construction. I strongly recommend sending your device for RMA in case it does not work as expected.
Mateusz.
CLA,CTD,CLED
(4,112 Views)
Thank you.
I think this is no secret. I can save 1/3 of the power if the resistor is disconected. So I installed a Switch for it. I think the resistor is for heating.
(4,109 Views)
