PXI
PXI IVIC support using MXI
I have an NI PXI 1031 chassis with an NI PXI 8360 that connects to a PC over MXI Express.
I need to install some Agilent PXI modules that use only IVI-C drivers, supplied by Agilent.
When I had a PXI embedded PC, I called these drivers from Matlab and that worked OK.
How does this work when using MXI connection?
Thanks very much,
John Reyland
(2,289 Views)
Hello John,
Have you already installed in the computer the PXI Platform Services and the drivers needed for the controller to be used?
Besides that, I think you would need NI-VISA to be installed. Do you have that already? Have you tried using the modules and got an error, or are you just starting the setup?
Regards.
(2,263 Views)
