PXI
PXIe-8234 (Ethernet Interface) - speed and flow control
Where I can set transmission speed and flow control for the PXIe-8234 card? The Properties >> Configure >> Advanced window lacks these settings.
I am receiving lots of "TCP previous segment not captured" in the Wireshark from the Ethernet Interface. I would like to set the slowest possible speed to be sure that the issue is not related with too slow capture speed of the Wireshark.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(2,804 Views)
Hi Michał ,
To be able to access the settings of the card make sure that you have the latest Intel drivers installed for your card.
Intel® Network Adapter Driver for Windows 7
You can find the following settings in the Device Manager in the Ethernet ports properties:
Speed:
You can set up the speed in the Link Speed option.
Device Manager>>Network Adapters>>(the port which you want to set up)>>Properties>>Link Speed
Flow Control:
You can also change the Flow Control settings.
Device Manager>>Network Adapters>>(the port which you want to set up)>>Properties>>Advance>>Performance Options>>Properties
Ambrus Gregor
Ambrus
Technical Support Engineer
??It's just business ??
(2,730 Views)
