PXI
PXIe 4330
I am using a PXie 4330 (Sensor Input) to read signals coming from a Pressure Sensor.
The 4330 module offers to remove noise by Antialiasing filter.
I would like to know, where I need to select the Antialiasing filter option? I have to choose this option on the Labview 2012 program?
or the Antialiasing filter is always "on" from the moment you are reading an input?
Thanks.
(5,409 Views)
You should not have to turn on the antialiasing filter on the 4330. It should automatically filter out certain frequencies of noice during the normal process of taking a measurement.
Matt W.
(5,366 Views)
