PXI
p2p streaming in PXIe cards from development pc
Dear community,
Is it possible to perform a p2p streaming communication between two PXIe FlexRIO cards executing from the development computer (and not from the PXIe controller)?
Both cards are placed in a 1082 chassis with a 8108 RT controller. The problem is that one of the adapter modules has some issues with RT OS, so we need to use it under Windows.
The proposed solution is to add both FPGA targets to "My Computer" (development pc, windows) in the LabVIEW project, and execute the host which configures the p2p stream there.
At this point, -63193 error saying that "The requested feature is not supported" are displayed in the "P2PReader.Get Peer To Peer Reader" and "P2PWriter.Get Peer To Peer Writer" blocks.
Thank you in advance.
P.S. executing the same code under the RT controller there is no p2p error (but the FPGA target does not work properly)
Message 1 of 1
(4,875 Views)
