04-08-2020 06:07 PM
I'm interested in using a PXIe-4492 module for measuring several inputs. Specifically, I would like to read in a signal from two accelerometers and six strain gauges. Since the module has 8 inputs, will it be capable of measuring each of these devices? What is the sampling rate of the module?
I am also looking into using a PXIe-4430 for measuring the voltages generated from the strain gauges (after the signals have been amplified). The PXIe-4430 has 8 channels as well. My understanding is that it should be able to read the signal from six different strain gauges, since there will be six input voltages and each of the strain gauges can be connected to a common ground. Is that correct?
04-09-2020 10:17 AM
Hi there,
The PXIe-4492 is great for the acceleration measurements. The device does have 8 inputs which can all be used at the same time to simultaneously sample sensors. It can sample data at a rate of 100 S/s to 204.8 kS/s. I wouldn't recommend this device for strain gauges, though. It doesn't have the excitation lines that you'll probably need.
The PXIe-4330 is a better choice for strain gauge measurements. It has 8 channels that can be simultaneously sampled, so you can use this for your 6 strain gauges. It's also designed for bridge measurements, so it has the required excitation lines available for each channel.
