PXI
PXIe-4844 signal problem
Hi I have some issues with a NI-XPIe-4844 module :OsiPIXe_4844.jpg
When nothing is connected to the module, I should have almost a flat signal for every wavelength, but instead I've got this signal
. As you can see I've got a peak of reflection in high wavelength. Do you have any simple solution for my problem or should I just change system?
Message 1 of 1
(1,580 Views)
