PXI
PXIe-5624 and PXIe-5644R bit file generation
Hi folks,
I would like that someone just confirms that there is no support to build FPGA bit files for PXIe-5624 and PXIe-5644R using LabVIEW FPGA 2017.
I am not sure why there is a restriction to use only LabVIEW 2015 FPGA module for building bitfiles for these platforms. Maybe I misunderstood something?
Thank you in advance.
(2,583 Views)
Same here. Cant identify target or install NI IF Dig. Tried some experiments in 17 but slammed by 14 DLLs.
I sure hope I'm not stuck with an $18k brick.
(2,360 Views)
