PXI
PXIe-8840 problem with PXIe-4463 and PXIe-4492, error code 200757
I'm using a PXIe 8840-Card in a 1062Q-Chassis, with two board card PXIe 4463 and one board card PXIe 4492. I plan to use Veristand collaborative with simulink to process a simulation. I set system RT at 5000hz, so the board sample rate could consistent with system RT. But, I got error code - 200757 to deploy with “device input does not support the sample rate defined “.
So I did a trouble shoot to test one another card, the simulation works well with PXIe-6368. I could find what`s issue of the error - 200757.
The following is my debug:
ï Start Date: 2018/7/4 16:46
ï Loading System Definition file: D:\NI\mod\mod\mod.nivssdf
ï Initializing TCP subsystem...
ï Starting TCP Loops...
ï Connection established with target Controller.
ï Preparing to synchronize with targets...
ï Querying the active System Definition file from the targets...
ï Stopping TCP loops.
Waiting for TCP loops to shut down...
ï TCP loops shut down successfully.
ï Unloading System Definition file...
ï Connection with target Controller has been lost.
ï Preparing to deploy the System Definition to the targets...
ï Compiling the System Definition file...
ï Sending reset command to all targets...
ï Preparing to deploy files to the targets...
ï Starting download for target Controller...
ï Opening WebDAV session to IP 192.168.68.21...
ï Processing Action on Deploy VIs...
ï Gathering target dependency files...
ï Downloading mod_Controller.nivsdat [232 kB] (file 1 of 3)
ï Downloading CalibrationData.nivscal [0 kB] (file 2 of 3)
ï Downloading mod_Controller.nivsparam [0 kB] (file 3 of 3)
ï Closing WebDAV session...
ï Files successfully deployed to the targets.
ï Starting deployment group 1...
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error -200757 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
(3,835 Views)
Have you tried setting sample mode to waveform? DSA must receive more than one sample at a time, so single-point acquisition is not supported and will throw this error.
(3,802 Views)
Hello AvatarAang,
we did the test by change the sample mode to waveform. Veristand still could not deploy.
Here, I attached the screenshot of our config.
(3,796 Views)
Dear ChandlerParis,
Thanks for the screenshots.
Have you tested whether increasing Acquisition size or using Continuous Acquisition mode changes the error at all?
(3,787 Views)
Dear AvatarAang,
We also tried to change the increasing Acquisition size or using Continuous Acquisition mode, we could not find correspond system mapping.
if we use single point sampling mode, it jump error code directly.
If we use wave mode, we could not find correspond system mapping.
We kind of stack here.
(3,771 Views)
Do you get an error code? If not, can you paste the exact error description?
Thanks in advance!
(3,759 Views)
I met the same problem just as you, do you solve it now? if yes ,could you please share your solution? thank you!
(3,717 Views)
