PXI
PXIe-5645r Configuration
I am using PXIe 5645r for RF Signal generation. I am using script mode for waveform generation. I want to get I-Q out along with the RF out from single module for same parameters. Can we do that?
(2,483 Views)
Hi asadliaquat,
When you say you want to get IQ out along with RF out do you mean that you want to generate IQ out of the front of the 5645? If that is the case, there are no ports available for outputting baseband IQ data on the 5645. You will have to use something like the PXIe-5820 which has specific IQ outputs.
Cheers,
Michael
Michael Bilyk
Former NI Software Engineer (IT)
(2,456 Views)
