PXI
PXIe-6355
           I have PXIe-1073, want to install PXIe-6355 , can I use  PXI-6255 cable to connect PXIe-6355 to PXIe-1073? second question is how many PXIe-6355 can be installed in PXIe-1073? Thanks!
(1,364 Views)
The PXIe-1073 is a 5-slot chassis, meaning it can hold 5 PXIe cards in it.  You then need a MXI connection to your PC to use it.  It looks like you should be able to use the cable you used to route the signals for the PXI-6255 with the PXIe-6355.
(1,344 Views)
What do you mean by "PXI-6255 cable to connect PXIe-6355 to PXIe-1073"?
PXI(e) modules are inserted into the chassis directly. There is no cable connection.
Are you referring to the MXI cable connecting PXIe-1073 to the host PC or the SHC68-68 cable connecting DAQ device to the terminal block?
PXIe-1073 has 3 Hybrid Slots and 2 PXI Express Slots, so theoretically it can support 5 units of PXIe-6355.
However, you should consider Performing a Power Budget on a PXI/PXIe System
Besides, PXIe-1073 only supports 250MB/s of throughput. All PXIe-6355 might not be able to run at full performance. See What Is the Maximum Throughput On My USB cDAQ Device? for the throughput calculation.
https://tmesystems.net/
(1,337 Views)
Thank you for quick responding!
5 slots in PXIe1073, install 4 Pxie-6355 and 1 pxi-6514 should be fine, right? in PXIe-1073 spec show 3 hybrid and 2 express, what does hybrid mean? Thanks!
(1,337 Views)
sorry confuse you, yes, I mean the cable connect to scb68A , do both PXI 6255 and PXIe06355 use same cables to scb68A? Thanks!
(1,328 Views)
See PXI Card Compatibility With PXIe Chassis
They both use the same SHC68-68 cable. Reference:
62xx Models : DAQ Multifunction I/O Cable and Accessory Compatibility
63xx Models : DAQ Multifunction I/O Cable and Accessory Compatibility
(1,307 Views)
Thanks a lot for your help!
(1,292 Views)
