PXI
PXIe 6363: Pin14 (+5 V Connector) usable for powering a Sensor with 60 mA?
I have a question about Pin Nr. 14 at the Connector of the PXIe 6363 Module:
(I am not sure if it is the correct information I found in the datasheet).
Is it possible to connect there a Sensor which consumes 60 mA @ 5 V?
Thank you very much!
(2,846 Views)
Accepted by Tooly
According to the spec, that pin has a 1A current limit.  So you can use that to power your sensor.
(2,836 Views)
Ok, thank you very much for your help!
(2,822 Views)
