PXI
PXIe-7820R fpga with veristand
Iam using PXIe-7820R to prepare a FPGA custom device in veristand. I tried to utilize the fpga addon custom device from github, but it seems many files were missing while extracting the zip. Iam new to custom devices. Did anybody worked with this kindly help me to sort out this issue. would ne more helpful. Iam using LabVIEW 2021 and Veristand 2021. Thanks in Advance.
Magesh
(945 Views)
If you just want to use it, you can download the compiled files from Releases · ni/niveristand-fpga-addon-custom-device
If you want to modify the source code, you would need to install all the dependencies.
https://tmesystems.net/
(917 Views)
