PXI
PXIe-7846R Triggering
I have two PXIe-7846R running  LabVIEW FPGA code monitoring the PXI_Trig0 line.  I would like the host program to enable the PXI_Trig0 high to start the two FPGAs running their application.  I have a PXIe-8840 controller.  Reading the forums and documentation is appears the a PXIe controller cannot control the PXI_Trig lines.
This that correct?  If not is there an example of a controller programming the lines.  All the examples shows one module triggering another module.
Paul
(3,560 Views)
(3,540 Views)
Yes, that is where I found this:
It is recommended you do not use the PXI controller trig line to trigger your measurement. Instead use another trigger source, such as a software trigger or a hardware trigger from an I/O module with an available counter output.
It is a little bit confusing, since a software trigger is code running on the controller.  Unless they are talking about a software trigger to a module in the chassis that causes it to set the Trig line.
(3,537 Views)
Accepted by topic author Paul_Knight_Lockheed_Mart
(3,526 Views)
Thanks for you help.  I was able to get the program to work, by using two triggers.  Each PXIe-7846R monitors a trigger that the other PXIe-7846R controls.
(3,509 Views)
