PXI
Use SFP Transceiver in PXIe-6592
I am using NI PXIe-6592. I tried to run the example project "NI PXIe-6592R Aurora Simple Streaming", but failed. The program is suspended at the write port.vi. I connected SFP transceiver to port 0 and port 2 instead of SFP+ transceiver. Can I use SFP transceiver in PXIe-6592?
Thanks.
(3,668 Views)
I don't think the SFP transceiver's are going to work for you. The 6592 requires SFP+ and from what I've read, SFP aren't compatible with SFP+ connections (SFP+ can be used in SFP connections, but not the other way around).
6529 Spec Sheet
http://www.ni.com/pdf/manuals/374637c.pdf
Stuff about SFP vs SFP+
http://www.siemon.com/sis/application-guide/2010-08-20-FAQs-for-SFP-plus.asp
(3,649 Views)
according to the datasheet for PXIe-6592, it only support SFP+ transceiver and not SFP.
SFP transceivers are not recommended to use with the selected PXIe card.
(3,636 Views)
Thanks for your reply.
According to the instructions in Wikipedia, it is possible to design an SFP+ slot that can accept a standard SFP module. Some routing and Ethernet switch equipment allows for the use of a 10 Gbit/s transceiver at lower Gigabit Ethernet speed, such as with a 1 Gbit/s 1310 nm LX SFP.[27][28]
https://en.wikipedia.org/wiki/Small_form-factor_pluggable_transceiver#cite_note-28
I think I need more detailed information about the SFP+ slot in 6592.
(3,604 Views)
