PXI
PXIe-8031 in PXIe-1082 causing Driver Verifier DMA Violation BSOD on Win10
Yes, we've determined that Kernal DMA Protection is causing issue with some of our modules when used with the 8301 remote controller.
If you can't find a Kernel DMA Protection option in the BIOS to disable, try looking for Virtualization Technology for Directed I/O (VTd) and disable that. This should stop the BSoDs. This is the only work around we have at the moment and are actively working on a solution that allows for Kernel DMA Protection to be enabled while using the 8301.
Message 11 of 33
(5,484 Views)
Captain_K,
! found the Virtualization Technology for Directed I/O (VTd) setting in my BIOS and disabled it.
I no longer get the BSOD with “Driver Verifier DMA Violation” error but the system still does not work right when any PXI cards are plugged into my PXIe-1078 chassis with the PXIe-8301 Thunderbolt controller.
NI SMBus Controller has yellow exclamation point in Device Manager.
Devices and Interfaces in MAX is all messed up.
The system works fine when only a PXIe-6361 DAQ card is plugged into the chassis with the PXIe-8301 controller.
This same chassis with a PXIe-8360 controller card connected to an older laptop via ExpressCard-8360 works just fine with all PXIe and PXI cards installed.
My laptop with Thunderbolt 3 ports is a Dell Precision 7740 Workstation.
PXIe-1078 Chassis:
Slot 1: PXIe-8301 Controller
Slot 2: Empty
Slot 3: PXIe-6361 DAQ
Slot 4: Empty
Slot 5: PXI-4065 DMM
Slot 6: PXI-5421 FGEN
Slot 7: PXI-5105 8 CH Scope
Slot 8: Empty
Slot:9: PXI-4070 DMM
Please see Device Manager screen shot, MAX Devices and Interfaces screen shot and ni_support.zip.
Message 12 of 33
(5,459 Views)
Please check if you've enough PCI busses allocated to the Thunderbolt to enumerate the slots on the chassis
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LiQSAU&l=en-US
You would need roughly 10 free busses on the computer to properly enumerate all the slots.
https://www.ni.com/en-us/support/documentation/supplemental/14/understanding-mxi-express-enumeration...
Santhosh
Soliton Technologies
Message 13 of 33
(5,419 Views)
I had the same Problem causing a Bluescreen with DMA Violation Error with the following Setup:
Laptop: Dell Latitude 7400
NI PXI-1078 Chassis
NI PXIe-8301 Thunderbolt MXI Express Card
NI PXI-8432 -> Accessing COM Port Caused the Bluescreen!
Solution:
- Deactivating Kernel-DMA_Schutz via BIOS indirectly:
I Disabled
  • Intel Virtualization Technology.
  • Intel Virtualization Technology für I/O (VT-d)
Description from MS for ACTIVATION of this Security Setting:
https://docs.microsoft.com/de-de/windows/security/information-protection/kernel-dma-protection-for-t...
Message 14 of 33
(5,386 Views)
Can you provide the specific error code associated with the SMBus controller yellow bang in device manager?  It should be displayed in Device Properties.
Please also provide C:\windows\inf\setupapi.dev.log.  This is a log of driver initialization behavior, and may help explain the problem with the SMBus driver.
Message 15 of 33
(5,317 Views)
I am experiencing the same issue, are you able to find the solution? thanks
Message 16 of 33
(4,870 Views)
Message 17 of 33
(4,857 Views)
Please these snapshots. I've also uploaded Setupapi.dev Thanks for your help
Message 18 of 33
(4,828 Views)
Code 10 on NI-SMBus is very likely related to a known issue with newer Thunderbolt hosts, for which a patch was applied in the recently released PXI Platform Services 20.7.  Please upgrade and report back to confirm the problem is resolved.
Note that the Code 10 error on NI-SMBus is not related to the DMA Violation error described in the title of this thread; any DMA settings you have changed to resolve those sorts of issues should be left alone even after updating the driver.
Message 19 of 33
(4,818 Views)
I also had the BSOD error that was corrected by disabling Virtualization Technology for Directed I/O but after that I then had the Code 10 error in device manager and the only way I got my thunderbolt controller to work with my PXIe-1078 chassis was to have a PXI card that did not require an NI driver in the chassis. In my case having a PXI-8231 network card in the chassis allowed the system to detect other cards without the Code 10 error in the device manager.
I just updated to the PXI Platform Services 20.7 driver and this has cured all of my problems with the thunderbolt controller.
Thanks so much for posting this update!
Message 20 of 33
(4,806 Views)
