PXI
PXIe- 8135 OS update
I was able to update to Windows 10 an PXIe-8133 and PXIe-8135. It was straightforward.
The trick was to start with Windows 7 working on the module (HAS to be 64 bits version), and then updating to Windows 10.
I started one module with original installation on Win 7 and the other had 32bit version, so I installed a fresh Win 7 64bit, updated with the updater bought on eBay, and both unit have been resold to a customer of mine. Very Happy indeed from getting these two devices in Windows 10 v1909 for a very cheap price.
One for the team!
Gaston
OptoElectronicsRefurbish@gmail.com
Message 11 of 17
(2,298 Views)
I just upgraded my NI PXIe-8135 controller to Windows 10 Pro 21H2 (from a MediaCreationTool ISO on a bootable USB stick), and it all worked fine. I didn't need the old Windows 7 additional driver package that NI provides at https://www.ni.com/en/support/downloads/software-products/download.pxie-8135-firmware-and-additional... because Windows 10 already comes with almost all the required drivers.
There were only two unknown devices listed in the Device Manager after I had also installed the usual NI PXI Platform Support package, NI 488.2 GPIB driver, and the drivers for all my PXIe modular instruments. One was a "NIC7019 Trigger Router" for which there is a Windows 10 compatible driver available at https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000015AWVSA2&l=en-GB and the other was for an "Intel Management Engine interface", for which Windows Update offered me a suitable driver as an optional update. (NI's Windows 7 additional drivers ZIP would also have had an older version of that Intel driver.)
So so far the only reason that I can think of why the NI PXIe-8135 might not be officially supported for Windows 10 is that Intel says that their Ivy Bridge generation of CPUs is supported for Windows 10 only for updates: https://www.intel.com/content/www/us/en/support/articles/000006105/processors.html
Message 12 of 17
(1,832 Views)
We work with an image of WIN10 that we put on a disk. This disk is using the Windows UEFI boot but is not available in the BIOS. So at the end, the disk is not recognized as a WIN10 disk but just a non-bootable disk.
We have also many PXIe-8840 where this UEFI is supported in the BIOS. There we have no issues with this disk image.
Anyone an idea how to solve this for PXIe-8135?
Wouter
Message 13 of 17
(1,570 Views)
Wouter,
There appears to be no mention at all of "UEFI" in either the user manual or the BIOS setup utility of the PXIe-8135, so I would assume it is still an old-fashioned pure BIOS device, without any UEFI or GPT partition support in its firmware. You will have to do either a fresh Windows 10 install (as I did without any problems, see above) from a USB stick that has a traditional BIOS bootloader and MBR partition table (made with Media Creation Tool or Rufus), or if you want to just drop in a disk image, you have to prepare another such disk image on some machine in pure BIOS mode (with MBR partition table).
(Lack of UEFI support also means that Windows 11 won't install. Luckily, NI has started in 2018 to provide Linux versions of their PXI drivers, so a switch to a Linux distribution supported by these drivers is is now also an option for keeping the PXIe-8135 alive for long after the end of Windows 10 support.)
Message 14 of 17
(1,561 Views)
Hi All
I know this thread is a little bit old, but maybe someone has experience with this same issue.
I have a PXIe-8135 with a new HD. I installed Windows 10 from scratch + BIOS and peripheral drivers
Almost everything is OK, besides the monitor. It is recognized as Microsoft®​Basic Display Driver (MBDD)  and therefore with low resolution 😣
I know that the GPU is old ATI radeon E4690 and it doesn't support Windows 10.
Does someone have a tip/suggestion or experience with this issue?
Any help and idea will be super helpful
Dalia
Message 15 of 17
(582 Views)
(I know old thread)
Quick follow-up since I just saw this. UEFI booting is supported on the NI PXIe-8135 controller (I tried it on BIOS version 1.3.0f0)
Message 16 of 17
(115 Views)
Hi DaliaR
I installed the E4690 Drivers for Windows 7 (Revision Number: 8.961, Release Date: 2012-06-08) successfully on an NI PXIe-8135 controller doing the following:
1. Download the driver and extract all files from the .zip file.
2. Open the Device Manager, navigate to the Display adapter, select the ATI option, right-click and select "Update driver"
3. Select the "Browse my computer for drivers" option
4. Select the "Let me pick from a list of available drivers on my computer option"
5. Click "Have Disk..."
6. Click "Browse"
7. Navigate to {your extracted files from step 1} -> Drivers -> Display -> W76A_INF and select the "CH137848.inf" file.
8. Click "OK", click "Next" and enjoy proper display resolution! 🙂
Since these drivers were never tested by AMD/ATI on Windows 10, they might not be fully stable under all circumstances, but it might work for you.
Message 17 of 17
(105 Views)
