PXI
PXIe-8135 onboard ethernet and IMAQdx
Does the onboard ethernet PHY on the PXIe-8135 support IMAQdx or is an additional ethernet card recommended?
Thanks ,
Mike
(4,751 Views)
Yes you can use the IMAQdx drivers and acquire images with a PXIe-8135.  The only limiting factor maybe whether or not you can use the high perforamnce ethernet drivers.  If you cannot, you will have to limit the packet size to 1500.  I am currently checking the specification on this and will post later what I have found out.
Greg H.
Applications Engineer
(4,737 Views)
