PXI
PXIe Camera Link card support on PXI
I'm currently using LV2021 RT to target a PXIe-8840 embedded controller running Phar Lap OS. Is the Camera Link frame grabber card PXIe-1435 supported on Phar Lap and is there a road map for the introduction of support for the same card on NI RT Linux on the 8840?
Rob
(1,157 Views)
Based on the available resources it should be possible.
You should be able to install NI Linux Real-Time on the PXIe-8840.
And it should work with NI Vision Builder for Automated Inspection and NI Vision Development Module.
__________________________________________
The best way to thank, is to give KUDOS
(1,114 Views)
