PXI
Peer to peer streaming on PCIe
The Peer to Peer streaming functinality is described in the article linked.
The list of devices supporting it is all PXIe. Since the technology is based on PCIe, is there any way to enable it in a PCIe solution on an NI FPGA card?
The reason I'm asking is I'm developing a solution on an NI FPGA that is targeted to work in a Desktop workstation, but I want to know if I have any contingency in case I run out of processing power and would need to add an additonal FPGA module?
Going down the PXI path would not be financially viable for me if I'd reach that point.
Thank you,
WibJ
(3,327 Views)
NI doesn't support custom configurations as you're describing so we wouldn't be able to provide guidance on doing so. However, it may be possible. You would want to contact the motherboard manufacture to discuss the details with them and ensure that the card you're using is listed in the P2P article as having P2P functionality.
RF R&D
(3,301 Views)
