PXI
Problem with PXI - missing modules in MAX
I have a test bench based on PXI 1078 chassis controlled with a PC via PXI-8360 and PCIe-8361.
Since some time I have an unexpected problem -  randomly during the test (CVI app) LIN module (PXI-8516) appears with cross mark in MAX, then the test sequence stops due to the missing hardware.
There is only one error window showing up:
It's very confusing why that error is about PXI-6259 Multifunction I/O Module, not LIN module.
Even after replacing the LIN module with a new one, or swapping slots in PXI, the problem still occurs.
Reset of MAX configuration and installation of MXI-Express BIOS Compatibility Software according to proper instruction (setting DIPswitch on 8361 card) also didn't help.
Have you got any ideas what can I do to solve this problem?
Message 1 of 1
(994 Views)
