PXI
Error in Cal Exec when using 5720A Series II
I am receiving this error when using Cal Exec and trying to calibrate a PXI 4070 DMM card with a 5720A Series II calibrator.
 Error -1074001424 occurred at Error -1074001424 occurred at cex_FL5XMCal_ConfigCalibratorOutputAndWait.vi
I cannot find anything on this error or how to fix it.
(4,078 Views)
Hello ledwards,
What version of Cal Exec are you using? What are you using to control the calibrator? Have you been able run any other calibration or is the error specific to this device?
Glenn
(4,058 Views)
I am having the same error when in the adjustment part of the procedure.
All works find when verification takes place then I get the error and cant proceed when adjusting.
This is on the 2.2AMP DC test.
I have uploaded a couple of pictures to help.
I am using Cal Exec version 3.5
Fluke 5730A calibrator in 5720A emulation.
Any help would be most appreciated.
Thank you
(2,016 Views)
