PXI
XJ4 connector suggestion?
I have several PXI cards with J2 populated - preventing use in newer system bays.
What is the model number of the XJ4 connector that replaces it to convert to a hybrid?
(1,679 Views)
I ordered a few of these last year, https://www.mouser.com/ProductDetail/571-2336682-1 . I tried replacing J2 myself on a relay module and I just made a mess out of it. The connectors are press fit and I didn't have the correct equipment to do it. The connectors are held in the board quite tightly.
(1,630 Views)
Thank you, I had not discovered that one on Mouser.  I got a call from an ERNI rep saying the right one is 214443, but they were out of stock on Digikey so I ordered 214444, which has a different key.  I will just Dremel off the key.  But I have yet to find someone to do the work.  This is worthy of a youtube DIY video if someone knows how to do the rework....
(1,625 Views)
