PXI
Problems after update RT-System from LV-RT 8.5 to 8.6 (NiRioRpc, lvalarms)
Hello NI-Support-Team,
I updated an LabView-RT Controller from LabView-RT 8.5 to 8.6. After the update i have two problems:
- The RT-Target boots with an error: Error loading 'lvalarms.dll': Missing export 'SetProcessAffinityMask' from 'Kernel32.dll'
- The second problem is when I connect to the RT-Target for the firt time I get an deployment error: Failed to load shared libary NIRioRpc.dll on RT Target.  When I disconnect and connect again, the error don`t occurs.
Is there any context between these to problems? How to solve them?
I already reinstalled the System, but still the same problem.
My system components:
LabView 8.6
LabView-RT 8.6
PXI 8106
PXI 7852R
PXI 7833R
PXI 2566
PXI 6251
PXI 6115
PXI 8461
Kind regards,
Henning
(3,489 Views)
Hello Henning,
could you please post your phone number oder your email address.
I will try to contact you.
Kind regards
Ulrich
Application Engineer
NICER
(3,466 Views)
Hi Ulrich,
you can use this e-mail Henning.Piekert@philips.com
Via e-mail I also can give you my phone number.
I already solved the 'lvalarms.dll' problem on the RT-Controller, by reinstalling the whole system (including all drivers).
Kind regards,
Henning
Message Edited by HenningP on 03-24-2009 02:33 AM
(3,456 Views)
