PXI
Problems building installer in LV8,5 with NI-SCOPE, NI-SWITCH or NI-FGEN
I have problems building an installer when including either NI-SCOPE, NI-SWITCH or NI-FGEN under "Additional installers". This problem occured after upgrading to LV8.5.
The error message is as follows:
CDK_Build_Invoke.vi.ProxyCaller >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_Build.vi >> NI_MDF.lvlib:MDFDistCopyList_CopyItem.vi
Loading product deployment information
Adding files to installer
Done adding files
Preparing to build deployment
Copying products from distributions
Copying distribution 'National Instruments Device Drivers - August 2007, Disk 2' from: G:\3000000\3000000 Technology&Products\Software\NI\Installers\LabVIEW 8.5\_SourceFiles\Device Drivers\DCD-Aug07-2\ to: C:\Documents and Settings\ofsjocor\Desktop\Test\Builds\
Copying distribution 'National Instruments Device Drivers - August 2007, Disk 3' from: G:\3000000\3000000 Technology&Products\Software\NI\Installers\LabVIEW 8.5\_SourceFiles\Device Drivers\DCD-Aug07-3\ to: C:\Documents and Settings\ofsjocor\Desktop\Test\Builds\
Copying distribution 'NI LabVIEW SignalExpress 2.5' from: G:\3000000\3000000 Technology&Products\Software\NI\Installers\LabVIEW 8.5\_SourceFiles\SignalExpress\ to: C:\Documents and Settings\ofsjocor\Desktop\Test\Builds\
Copying distribution 'National Instruments Device Drivers - August 2007, Disk 1' from: G:\3000000\3000000 Technology&Products\Software\NI\Installers\LabVIEW 8.5\_SourceFiles\Device Drivers\DCD-Aug07-1\ to: C:\Documents and Settings\ofsjocor\Desktop\Test\Builds\
Copying distribution 'NI LabVIEW 8.5' from: G:\3000000\3000000 Technology&Products\Software\NI\Installers\LabVIEW 8.5\ to: C:\Documents and Settings\ofsjocor\Desktop\Test\Builds\
*** Error: Windows SDK function returned an error. (Error code -12)
The system cannot find the path specified.
*** End Error Report
Done building deployment
Under "Details" it's written:
"Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
I've tried creating a very simple vi and build a new exe-file and installer, but the same happens as with my old project. The new project is attached here.
(3,226 Views)
I am able to build your installer without any problems. You mentioned you updated LabVIEW to 8.5. Have you re-installed all the toolkits, modules and drivers as well?
(3,170 Views)
