PXI
Python library "nidcpower" to NI PXIe-4163 SMU returns error on session open "-1074135040: IVI: (Hex 0xBFFA0000) Unrecoverable Failur"
I'll be honest that this is stumping us. You are the first to report it.
The driver seems to work, overall... except when called from python.exe
We can tell that the driver library loads successfully, and the error code is coming back from apparently the initialize function.
Could you try to capture the NI I/O Trace output to see exactly what parameters are being passed into it?
Marcos Kirsch
Chief Software Engineer
NI Driver Software
Message 11 of 44
(727 Views)
import nidcpower
import nidcpower.errors
try:
    session = nidcpower.Session(resource_name='PX1Slot3')
    session.abort()
except nidcpower.errors.DriverError as e:
    print(f"DriverError: {e.code} - {e.description}")
except Exception as e:
    print(f"An unexpected error: {e}")
Message 12 of 44
(720 Views)
Sorry, I had a error in slot naming, same result either way... trying multiple things
Message 14 of 44
(716 Views)
It looks like the wrong init function is being called, given your arguments. Try
session = nidcpower.Session(resource_name='PXI1Slot3',channels='0', independent_channels=False)
Jay
Senior Software Engineer
Driver Software
Message 15 of 44
(706 Views)
import nidcpower
try:
    session = nidcpower.Session(resource_name='PXI1Slot3',channels='1',independent_channels=False)
    session.abort()
Message 16 of 44
(692 Views)
Please remove the try/except. Let's see exactly which C library call the error is coming back from.
Marcos Kirsch
NI Driver Software
Message 17 of 44
(660 Views)
Please disregard this comment. niDCPower_InitializeWithChannels is deprecated in favor of niDCPower_InitializeWithIndependentChannels (which you are calling and which does accept individual channel names, if you are only opening a session to a single device).
Jay
Driver Software
Message 18 of 44
(661 Views)
Removed try/except trap:
import nidcpower
session = nidcpower.Session(resource_name="PXI1Slot3",channels="1",independent_channels=False,)
session.abort()
more simplier form:
import nidcpower
session = nidcpower.Session(resource_name="PXI1Slot3")
session.abort()
Message 19 of 44
(651 Views)
Not to go off topic, but using the python daqmx library, I have no issue communicating with the PXIe-6341 DAQ in slot 2 of the PXI mainframe PXIe-1084, over the Thunderbolt interface PXIe-1084.
import nidaqmx
with nidaqmx.Task() as task:
    task.ai_channels.add_ai_voltage_chan("PXI1Slot2/ai0")
    test = task.read()
    print(test)
Message 20 of 44
(647 Views)
