PXI
Reading Encoder data
Hi everyone,
I am using PXI and CompactRIO to build test systems. I wonder what is the best way to read the absolute encoder data, like Netzer VLG-60, on PXI systems. I investigate it and got some methods. I think the best option is FPGA. But i wonder any other relatively easy on application. I think counter modules like PXIe-6341, or PXIe-6612 might be implementable. I'm waiting for your suggestions in gladly. Thank You!
(1,103 Views)
It depends on the encoder output signal (SSi or incremental), and how many units of encoder you want to read.
Netzer does not have VLG-60 model. Which model are you using?
https://tmesystems.net/
(1,069 Views)
Hi, there is a typo. I'm gonna use VLX-60 absolute rotary encoder that have resolution up to 22 bit, between 17-22 bit. Here is the page of this encoder:
https://netzerprecision.com/products/vlx-60/
Is the PXIe-6363 module can do this? Or what is the best way that easy to application?
Thank you
(1,052 Views)
Since VLX-60 only supports BiSS-C or SSi but not incremental encoder.
Directly supported:
NI-DAQmx devices including PXIe-6363 don't support SSI natively. If you really want to use DAQ, you need to tackle two challenges:
  1. BiSS-C and SSi support only differential signal but DAQ only support single ended. You need to get a RS-422 to TTL converter.
  2. Then you can use hardware timed digital input to capture the waveform. However, there isn't any decoding readily available so you need to develop it.
(1,047 Views)
Thanks for your reccomendations.
The link which I mentioned previous answer, is about VLX-60 technical informations. In Electrical Data chapter, they indicate that this encoder has RS-422 differential serial output. In this case, do i have to prefer FPGA-based solution, the combination is for example PXIe-7972R & NI 6584, or can i read data through this output with serial interface modules like PXIe-8431? Therefore, there is some converter modules that i can purchase with the encoder. I drop some screenshots about this. Thank you again. serial converter.pngserial output.png
(1,019 Views)
