PXI
Recommended approach for PXI control from Python
thanks for your time.
I'm not going far ...
#-*- coding: UTF-8-*-*
from ctypes import c_bool, c_int, c_double, c_char_p, byref, windll, cdll
from ctypes.util import find_library
def c_string(s):
return c_char_p(str(s).encode('utf-8'))
lib_name = find_library('nidcpower_32')
dll = cdll.LoadLibrary(lib_name)#C:\Program Files\IVI Foundation\IVI\Bin\nidcpower_32.dll
vi = c_int(0)
dll.niDCPower_InitializeWithChannels(c_string('PXI1Slot7'), c_string('0'), c_bool(True), c_string(''), byref(vi))
answer:
C:\WinPython-32bit-3.6.3.0Qt5\PycharmsProject\test\venv\Scripts\python.exe C:/WinPython-32bit-3.6.3.0Qt5/PycharmsProject/test/test.py
Traceback (most recent call last):
  File "C:/WinPython-32bit-3.6.3.0Qt5/PycharmsProject/test/test.py", line 13, in <module>
ValueError: Procedure called with not enough arguments (20 bytes missing) or wrong calling convention
Process finished with exit code 1
 I don't find anything in the web about that. The PXI1Slot7 is an PXIe-4142
Message 11 of 15
(2,515 Views)
cdll and windll are for two different calling conventions (how functions pass arguments and return values), which is what it seems to be complaining about. You should be using windll.
Message 12 of 15
(2,512 Views)
The code below works. thanks a lot.
import time
def c_string(s):
dll = windll.LoadLibrary(lib_name)#C:\Program Files\IVI Foundation\IVI\Bin\nidcpower_32.dll
vi = c_int(0)
dll.niDCPower_ConfigureOutputFunction(vi, c_string('0'), c_int(1006))
dll.niDCPower_ConfigureVoltageLevel(vi, c_string('0'),c_double(3.1))
dll.niDCPower_Initiate(vi)
dll.niDCPower_ConfigureOutputEnabled(vi, c_string('0'), c_bool(True))
Message 13 of 15
(2,507 Views)
Great, happy to help
Message 14 of 15
(2,505 Views)
Adding some info in case anyone stumbles upon this thread... Some time after the first post some people started an open project to already wrap these NI drivers in Python. It can be found here:
https://github.com/ni/nimi-python
I haven't tried it myself but by the looks of it it tries to provide a Python interface for each and every one of the C-style functions in the original drivers. If you want to write something on top your code will look similar, but at least you won't have to deal with ctypes/cffi yourself.
Message 15 of 15
(2,170 Views)
