PXI
SMU PXIe-4139 Signal Generation and Real-time Measurement using LabView
I have a PXIe-4139 SMU. I have a customized current signal profile stored in a CSV file. I want to use the SMU to send out the signal and measure the response of the test subject in the meantime.
Is it possible? Is there a LabVIEW example that demos this or a similar idea? Even just a sine wave example would be great. Thanks.
(294 Views)
Checkout this example, modify it to source current instead of voltage, change the limit and range configurations to opposite.
Add in the logic to read the CSV for profile and send it to the DC power API as the sequence.
Santhosh
Soliton Technologies
(248 Views)
